Ir para o conteúdo principal
Lançado em 16 de setembro de 2016. Modelo 1660, 1778 Disponível como GSM ou CDMA / 32, 128 ou 256 GB / Ouro Rosa, Dourado, Prateado, Preto Mattte e Preto Brilhoso.
2264 Perguntas Visualizar todos
Replacement screen is different
I’ve purchased 2 different screens and both are not same as oem. I tried one of them and phone stays in boot loop. Put broke one back on for now. The ribbons are different for some reason. The picture on the order shows it to be like original. First picture is original and second is replacement.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
3 respostas
Pergunta mais útil
Are you trying to test the screen without the home or proximity cable attached? If so it will actually boot to home screen fine after about 4 mins 10 seconds .
If all the proximity cable and home cable are attached then it should be booting in the normal around 30 seconds .
Esta resposta foi útil?
Pontuação 1
1 comentário:
I have everything hooked up. It shows Apple icon then it shuts off then it shows icon again etc......... never goes past Apple icon.
My main question is why the cable is different and if that is a problem.
And if anyone else that has changed one had the one like I received.
Thanks for reply
por
I too have seen this on Chinese screens, both worked fine. I've also come across some with a chip along the ribbon which I presume are compatable with iPhone 8 but I can't confirm this.
Pontuação 1
1 comentário:
The first one didn’t work, I ordered a second from another ebayer and havnt tried it yet. Not sure why it’s different.
por
I think that it is a bad replacement screen. Where did you get it from? It is all aftermarket so it is difficult to find a good replacement.
Pontuação 1
3 comentários:
I ordered it on ebay, then I ordered one from another company and it was the same way. Not sure where to get a right one reasonable.
por
It's a possibility that you have damaged the homebutton or front camera ribbon. Have you left you phone to boot loop for 10mins? Sometimes they do come on eventually, we get lots in the shop that have this problem and worst case it can be the audio ic on the mobo.
por
I put the original screen back on and the phone works fine. So ribbons and mobo are fine. Ribbon just looks like it has something missing where the copper contacts are showing in picture.
por
Adicionar a sua resposta
Troy Pogue será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 4
Duração total: 73
