Ir para o conteúdo principal
Samsung's flagship phone, the Galaxy S8. Released in April 2017.
304 Perguntas Visualizar todos
Craked screen Glass or entire display broken?
Dropped the phone while running for a train smashed on the floor and well is basically useless since, Went into repair shops and without even looking at it they say it would be 320 euro to fix. The touch still works but the screen flashes when I turn it on and flashes white and black all over if you need pictures let me know.
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hello,
If there is effects on the display then the whole digitizer is probably at fault, so I'm afraid you would have to change it all
There is also a small probability that the fall damaged directly the motherboard, causing those problems, but it is far less common
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Conor será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 71
