Ir para o conteúdo principal
Released by Samsung in March 2016. Model SM-G930.
425 Perguntas Visualizar todos
Device keeps shutting off and rebooting.
After the screen replacement it randomly shuts off and restarts. i have tried the battery and a charging port as well as a factory reset and it is still shutting off frequently. is there anything else i could replace that will fix this issue?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Is it possible you might have damaged the NFC antenna? Might try leaving the rear cover and NFC antenna off the phone to see if it becomes more stable.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
elsa será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 193
