Ir para o conteúdo principal
Sudden shutdown under minimum load
Hi thanks for your help in advance this site and users who use it helped me alot.
My friend's laptop (Samsung R540)
Is facing sudden shutdown even under minimum load of only one program opened and with noticable heat on keyboard (caused by motherboard most probably) and he did try to clean the fan but it didn't make any difference.
Is there a way he can fix it. Or is there specific set of fans for such laptop he can buy to fix the problem?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hello Bakr gamer, This problem might be caused because of an overheating issue... Has he opened this computer before and forgot to tighten down the CPU cooler to have it work properly? Or the CPU heat detector might not be working properly as well. If this is the case of overheating I would try getting a new application of thermal paste.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Bakr gamer será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 8
Duração total: 166
