Ir para o conteúdo principal
Released June 2009 / 2.66, 2.8, or 3.06 GHz Core 2 Duo Processor
Reinitialize operating system question
This is an older MacBook Pro El Capitan 10.11.6 OS. I want to reintialize because it is used and has problems. Will the operating system still be there after I do this? I don’t have discs. Newbie to this type of Macintosh.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Irrespective of the problems you might have with the Mac, best thing to do is to take the easy way. Unless you already did, open system preferences and create a brand new user, then log out from your existing one and get into the new one. Unless it's a system problem this will give you a fresh and untouched user experience and might solve your problem. Reboot your Mac and keep pressed the command+option+P+R keys until you see/hear your mac restarting a second time, then release and let it boot normally..this will reset basic parameters and solve a few potential glitches.
If you don't have install discs you'll need to recover the Os via the net, but most of the times is not necessary to get that far to solve basic problems.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Tobin Voeks será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Ao todo: 78
