The battery door is broken, how can I replace it?
The battery door is boken, I need to replace.
Esta é uma boa pergunta?
Is it the door itself or the hinge that's broken?
Probably the best source of spare it to look out for the same model on eBay advertised as "spares or repair" and cannibalise the door. Assuming the hinge is ok you'll probably find you can remove the door from the hinge just be undoing a couple of screws, and hence fit the replacement.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Duração total: 792
