Ir para o conteúdo principal
Repair guides and support for smaller headsets that rest on top of the ear, also known as supra-aural headphones.
Plantronics BackBeat PRO Right ear not working
I've aquired recently a used pair of Plantronics BackBeat PRO, and got the next issue - the right ear is not working at all, ar there any guides of disassembling the headphones and/or some advice related to reparing appeared issue?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
Typically, when you pull the ear cup padding back, you will find 3 or 4 screws that hold the driver plate to the cup. Another setup is a series of slots and tabs. There, all you need to do is use a small flat tip screwdriver to disengage the tab and separate the plate from the cup
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Eugen-Andrew Coliban será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 18
Ao todo: 4,778
