Errors E106 and E101
I get error E106 whenever I boot and when I try to update or factory reset I get E101. I used the factory update trick by holding eject and bind even after two beeps with a USB drive plugged in to instantly start updating but every time I try to update or factory reset I get error E101. When it says checking update, i checked on the drive and saw that it does move the update files to the disk but it doesn't install them. I have repartitioned the hard drive with ludvig jerabeks Linux tool. I tried every USB option available. Any ideas on what these error codes actually mean? I know E101 has something to do with updating.
Oh and I can't send it to Microsoft because my warranty period has ended and I don't want to pay half the retail price just to let them repair a known issue.
Esta é uma boa pergunta?
9 comentários
I've found out that e106 means that the osu1 files aren't the right ones. This probably means my console is in the insider program. I bought this console off ebay so I don't know. I'm gonna look up my dashboard version tomorrow.
por Piter
UPDATE
I've tried another partitioning script because the previous one was a bit shady. The console still shows the error when it finishes the 'installing update' part. Error E106 is a problem with the files. My dashboard version is from October '17 so it isn't an insider program version. I hope this information helps.
por Piter
I ran into this problem on a One S as well. I tried everything including switching HDD with a known working One S HDD and OSU1/2/3 update files.. Nothing worked.
I finally got the One S working again, simply by using another usb stick to put the update files on. My USB stick worked fine on another One S for update, but not on this particular console. So I put te update files on a different USB stick, and started the update: and it worked.
So try using a different brand / make of USB stick in this problem. Might help U as well. Kind Regards Jules
por Jules Louis
I had also problem with Offline update on my One X. It always ended with an error. But when I changed usb stick( thanks Jules ) then everything started working.
por Andrej Pollák
Did you get an answer? I am stuck in the same loop. Initially got a green screen, then got error code 106, then got e102 then tried offline update and staright away it goes to e101 error without even trying to download the files. Been quoted £204 via microsoft, am not paying this for a console that is a year and a half old and cost nearly £500 in first place :(
por Kobyr
Exibir mais 4 comentários
