Ir para o conteúdo principal
Released September 16, 2016. Models A1661, A1784, and A1785. Available in 32, 128, or 256 GB configurations in Rose gold, gold, silver, black, jet black, and (Product)Red.
1364 Perguntas Visualizar todos
How to properly clean dirty speaker grill the top one and the bottom s
When playing something using the phone volume, it’s low and barely hear them. Tried cleaning the top speaker grill with alcohol swabs it helps a little but don’t know how to clean the bottom speaker.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Properly cleaning the top and bottom, two methods.
Basic way, use a anti-static brush, some use a toothbrush but I always take the safe approach, and gently brush the grills. Do not dig the bristles into the grill, so use a swiping motion.
Deep Cleaning, open device, pull speaker and mic component out, use compressed air to blow from inside out, brush if needed.
Keep in mind that if you're going to open the device you need to be cautious with the gold contacts and electric static discharge on the device. Mishandling can lead to improper functioning of the device. Follow the examples on Ifixit for dissembling the unit.
Do note that Apple has some strict guidelines about "tempering" with the device. If something were to go wrong it may void out any warranty services.
Good Luck
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
BenSihte será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 25
Duração total: 3,945
