Ir para o conteúdo principal
Modelo A1278 Meados de 2010 / Processador 2.4 ou 2.66 GHz Core 2 Duo
794 Perguntas Visualizar todos
White display - Which LVDS cable do I get?
Hello all!
Backstory: This all started with an LCD that was showing bands of color or white that would fade in and out.
I purchased a replacement LCD from ifixit, installed it, and now I get a pure white screen. All other functions seem to work (keys, volume control, brightness control, etc...).
The Problem: I read up on these forums and decided that my LVDS cable was probably bad. A visual inspection doesn't give away any definite damage, but it does seem generally worn out.
So I got an LVDS cable from an online site that I thought would match mine. The description was for a MacBook Pro 13" Unibody. But when I went to install it, I noticed that it was the wrong size.
The connector is too wide on both ends.
My Question: Does any one know what the varying size LVDS cables are and which one I would need for my model MacBook Pro?
My Info:
  • MacBook Pro 13" Unibody Mid 2010
  • Model - A1278
  • LCD brand - LG
  • laptop serial (last 4) - WATM
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Apple MacBook Pro "Core 2 Duo" 2.4 13" Mid-2010 Specs
Identifiers: Mid-2010 13" - MC374LL/A - MacBookPro7,1 - A1278 - 2351*
por
Adicionar um comentário
2 respostas
Solução escolhida
It seems to only come with the display. Here are other answers to this same question: About LVDS cable MacBook Alu
I found this one: http://www.ioffer.com/i/Apple-A1278-MC37...
and here: http://www.techrestore.net/macbook-pro-1...
Esta resposta foi útil?
Pontuação 3
2 comentários:
Those links seem to be to the proper cables.
I wish there was a way for me to know for sure.
I've already bought one for $100 that turned out to be wrong.
Thank you for your answer.
por
Sorry, there is no part number. I would tell the seller exactly which machine you have before buying a second one.
por
The Replacement of wrong screen would burn out your graphic card. i did just same today. bought complete lcd on ebay and turns out it was a macbook air display packed on it. now its white screen,.. an attempt to buy original lcd from apple dealer, all stays white screen and my graphic card is Dead
Pontuação 0
Adicionar a sua resposta
nate será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 3,601
