usual SD card will not go in slot.Could something be blocking?
I have successfully used the card before now it only goes into the slot halfway. I do not see anything in the slot
Esta é uma boa pergunta?
Try rotating the card 180 degrees and inserting it. It will only go in one way.
Esta resposta foi útil?
I have the same issue, it's not the way the card goes in.
I got it from a pawn shop. Can't tell if there is an old card broken inside, or if the popup housing might be broken.
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 435
