Ir para o conteúdo principal
Late 2011 model, A1278 / 2.4 GHz i5 or 2.8 GHz i7 processor.
591 Perguntas Visualizar todos
Battery Failure with new battery MacBook Pro 2011
Hi! I just changed the battery and installed CoconutBattery.
I was in the middle of calibrating (at least, I think it was calibrating: it was the process of fully charging, then let it fully discharge, and charge it again). As soon as I unplugged the power, the charge jumped from 100% to 80% and Coconut shows Battery failure.
Did I got a faulty battery? Or is there something I could do like resetting SMC?
(I apologize for my bad English: it's not my native language and I guess I made a lot of awful mistakes :))
Esta é uma boa pergunta?
Pontuação 0
6 comentários
And now it automatically powered on as soon as I plugged in the power. it is not normal, I guess?
por
What was happening with the old battery? Would you now run Coconut with the mag-safe plugging in and post a photo of that.
por
Unfortunately coconutbattery trial expired so I cannot see the advanced info anymore. The free version only shows me this
https://i.imgur.com/fRHL0fA.png
and this is the info in About this Mac (I don't know if it may be useful)
https://i.imgur.com/iqpWHgO.png
Btw I was using the Mac and it powered off at about 60% charge. Afterwards I tried to power it on but I couldn't get it past the apple logo. Is this normal? With my old battery, once it shut off because of the charge I couldn't even get it to seem to start.
por
your latest update is when using the old battery or the new one?
por
When using the old one
por
Exibir mais 1 comentário
Adicionar um comentário
1 resposta
Pergunta mais útil
Once in a while I get this issue with new batteries. Try at least 5 cycles of full charge and discharge and see whether the issue will go away.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Thank you. I was beginning to think it would be better to put in the old battery, but I'll try to wait.
Also, it takes a lot to fully charged, compared to the old one.
por
Adicionar a sua resposta
ghilo89 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 492
