Ir para o conteúdo principal
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
PSP 2000 Battery not working correctly
I bought a brand new PSP 2000/3000 battery off amazon a while ago since my other one seemed to have died. It worked when I put it in the for the first time, but after that, the battery would disconnect and reconnect very quickly (at least according to the XMB and P Tester) The system would still work fine plugged in without the battery, but if I have the battery inserted while plugged in, the PSP would assume the battery is full after a couple of minutes and shut down, requiring me to remove the battery and the power adapter to boot back up.
I've also tried different adapters, 2 USB/Charging cables and an official Sony charger.
Can somebody help?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
I would say return it to Amazon as defective and buy from another seller there.
Alternatively, aliexpress has reviews on their items as well.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Jobel será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 34
Ao todo: 423
