Ir para o conteúdo principal
Model Number A1707. Released June 2017, this MacBook Pro features Kaby Lake processors up to the 2.8 GHz quad-core Intel Core i7 processor with Turbo Boost up to 3.8 GHz.
Not all of the trackpad is clickable
So ive noticed on my personal machine that i cannot click anywhere on the edge of the trackpad i have to click at least 1cm in from the trackpad in order for the force touch to even click, for example i cant even right or left click right in the corner this doesn't happen on the 13 inch im just wondering if this is normal as most of the time im using a bluetooth mouse.
Esta é uma boa pergunta?
Pontuação 3
4 comentários
You may need to visit a store which has one on display to verify. For some reason I think thats right the click area is not to the edge.
Apple is pushing to the touch mediphor like the newer iPhones. So now you press and hold to gain access to the right click menu.
por
The MacBook Pro trackpad is not all clickable I have one. 80% trackpad is clickable.
por
ah well I'm glad I'm not the only one I hope this might be fixed at some point now that I've noticed it, its really annoying
por
@danj it happens with both left and right I just stated right as thats most difficult as you naturally click in the bottom right
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Check with Apple to see if this is covered under their new program.
Keyboard Service Program for MacBook and MacBook Pro
https://www.apple.com/support/keyboard-s...
Esta resposta foi útil?
Pontuação 3
2 comentários:
i popped it into them today, they refused to do anything, i checked all the devices in the store and around 7 of them had the same issue however some of them didn't, at first i thought it was all devices.
por
Contact Apple directly at 1-800 MYAPPLE
por
I had the same problem.
Apple actually changed my trackpad/keyboard 3 times in a row before realising they couldn't do anything.
They then understood it was a broader problem affecting all new 15'macbook pro.
They explained to me that the haptic feedback does not cover the whole area of the trackpad. There is no fix.
Pontuação 2
Compared to the ones I've seen in store, the whole trackpad should be clickable? Even if half of your finger is off one side, it should still be able to be clicked? I would definitely try and take it into a store if possible and compare/get them to repair it for you.
Pontuação 1
1 comentário:
It appears on all or most of the 15 inches ive had the trackpad replaced twice and a new machine they say theres nothing they can do and its normal which it clearly isnt
por
Adicionar a sua resposta
lewis Barker será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 9
Últimos 30 dias: 18
Ao todo: 1,778
