Ir para o conteúdo principal
Xbox One controller was introduced in 2016 with the launch of the Xbox One S and adds Bluetooth support for Windows 10/11. This controller fixes many of the design flaws found on the Model 1537/1697 controllers and is much more reliable. This controller has been replaced with the improved Model 1914 controller.
163 Perguntas Visualizar todos
Sync Button came loose
The sync button/switch came loose from the circuit board on my son's 1708. I have the controller apart and the switch handy but it's not obvious if/what contacts to solder. It looks like there are four pads in roughly a _| |_ configuration. Would I solder all 4 ? I've also read to just forget it and use USB to sync.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
well its a slandered switch so im guessing solder all 4 like with the other two switches rb and lb im more looking for the best method to do this as sync button is so %#*@ small
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Michael Gallant será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 6
Duração total: 320
