Ir para o conteúdo principal
The April 2014 update of the 11" MacBook Air packs refreshed dual-core i5 and i7 Haswell processors and slightly increased battery performance.
100 Perguntas Visualizar todos
Booting to black screen with working LED backlight
I have an early 2014 11" MacBook Air that boots to nothing but a black screen. The LED backlight works, and I do not have a mouse cursor.
I updated the OS to 10.13 (minor revision would have been whatever was released December of last year). I was able to boot into my account after the update, but a couple weeks afterward the computer got very hot, shut down, and I ended up where I am now.
Things I've tried so far:
- Reset PRAM (option, command, P, R). Prior to this step I had no boot chime; after this I had the boot chime. This was the only step to make any noticeable difference.
- Reset SMC (shift, control, option, power)
- Try to boot to System Recover (command, R). Screen was still black. Attempted to right-arrow once to the recovery partition with no success.
- Try to log into to my account blindly, hit the power button to trigger the shut down pop up, hit 'S' to select "Sleep," and then enter. Once asleep, I should have been able to hard shut down and then boot back in with a working screen. No success with this.
- Open the back cover, disconnect the power connector from the batteries, hold down the power button, and then reconnect the power connector. No success here either.
Any other ideas?
Edit (3/26/18): Correct from 10.12 to 10.13.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Not that anyone is listening, but FWIW I tried one more thing that may or may not help future readers of this article.
Watched a YouTube video of a guy that removed the SSD, plugged in a bootable thumb drive, and booted while holding down Option. He said that if the various thumb drive boot options were listed then this was an indication that the SSD was bad. Sure enough, boot options were listed when I attempted this.
This confirms that my display and logic board are fine which would leave just about nothing other than the SSD. If I attempt a drive swap then I'll add the results here.
Esta resposta foi útil?
Pontuação 1
2 comentários:
Yes it will be a bad SSD in that case; a lot of the time when these go bad, it will sit on a black screen forever or a very long time. Usually the SSD will get hot too, which is a telltale sign
por
Thanks for the confirmation Reece!
por
Adicionar a sua resposta
Josh Jennings será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 2
Duração total: 762
