Ir para o conteúdo principal
Um headset gamer USB que proporciona uma experiência completa de som surround 7.1.
USB Wiring Not Working HELP PLEASE
Hi,
I have got fed up of cutting the cable and then soldering the two parts together because they always break anyway so I decided that I’m going to cut the wire and directly connect it to the USB however it doesn’t work.
I didn’t see which colours go where before desoldering them so I looked up the colours online and soldered them but not the headset is completely dead! I will appreciate if someone is able to help me out. I will attach a picture below. Thanks
Imagem
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Sorry but stupid me wired the USB port the other way because you have to flip the USB plastic to put it in the case and that means that the wiring that I have goes the other way around. Sorry about that
Esta resposta foi útil?
Pontuação 0
1 comentário:
Good learning!
por
Adicionar a sua resposta
Tom será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 8
Últimos 30 dias: 22
Ao todo: 1,911
