My Kenmore super capacity 3.5 will not spin
Model 970-C45092-30 will fill with water, agitate both directions drain the water but will not do the last quick spin. The digital timer just ends the cycle with anywhere from 7 - 11 minutes to go, cycle dependent. I cleaned out every Jose and the drain trap. Door clicks when it locks. It just won't spin.
Cheers
Esta é uma boa pergunta?
5 comentários
Rich Kibbee it will not spin at all or just not the last spin. Does the timer advance and finish the cycle?
por oldturkey03
Thanks for your responses, I am throwing in the towel, checked everything and all that's left is the control board and panel. Which I am not about to start swapping out at hundreds of dollars.
por Rich Kibbee
Where is the circuit board located?
por Andrew Fradette
por Andrew Fradette
I just got one and the door sensor keeps the machine from working
por Robin Wallace
