Ir para o conteúdo principal
The Coolpix S7000 was released in 2015. The camera has 20x wide optical zoom, Wi-Fi capabilities, and Near-Field-Communications (NFC).
20 Perguntas Visualizar todos
Telesccopic lens will not retract on the Coolpix S7000
Telescopic lens will not retract when camera is turned on or off. The entire telescopic lens stays extended.
Error message says "Lens error. Try again after turning the camera off and on".
I have tried to remove the battery, memory stick, turned on off multiple times.
Thank you,
Jeff
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
There are a few simple things you can try documented at https://therestartproject.org/wiki/Compa... but if none of those work then I'm afraid you may be out of luck.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Jeff será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 5
Duração total: 392
