Ir para o conteúdo principal
Device repair and troubleshooting for the 7" RCA tablet released in 2014, identified by model number RCT6773W22.
130 Perguntas Visualizar todos
My tablet will not charge
Actually my RCA Tablet model # is RCT6873W42 , haven't charged in a long time, it keeps trying to turn on will not take a charge. Tried to turn off but it keeps trying to turn on. Wasting any charge it may be getting
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi! Sounds like the charging port may be damaged, either by coming off the motherboard inside the tablet or damaged inside the port itself where you plug your charger in. If you can solder it is a DIY project. If not, you may need to get it repaired by a pro.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Lori Ortmann será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 61
