Ir para o conteúdo principal
The fifth-generation Volkswagen Jetta was introduced in January 2005.
Where is my camshaft position sensor located?
I have a 2008 Volkswagen Jetta Wolfsburg Edition 2.0 T. I need to replace my camshaft position sensor but can't find the location. Anyone know where it is located. I've found videos of the position on other years but none of them match mine.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
If you open the hood you take off the airflow engine cover and on the left side by the left headlight there's three fuel lines and it's just behind where the rubber hoses connect to the metal fuel lines there's one bolt that holds it
Esta resposta foi útil?
Pontuação 1
On the CCTA 2.0 TSI the sensor is located on the valve cover directly above the intake manifold. The connector will have three wires and a standard Bosch connector.
Update (11/27/2018)
Connector #2
Pontuação 0
1 comentário:
what is the number 1 pointing to I do not have that there
por
Adicionar a sua resposta
Brittany Kenney será eternamente grato(a).
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 17
Últimos 30 dias: 62
Ao todo: 5,848
