Ir para o conteúdo principal
iPhone not charging once battery is fully drained
Hi Community,
Recently I was fixing an iphone 6 plus that had water damage, i took it full apart and cleaned it with isoproply and replaced the charging port, battery and screen. After that the phone tuned on and worked perfectly, however after a week the phone would not turn back on after the battery had been fully drained. I replaced the battery and this fixed the problem however now i am having the same problem but i tested the charging port and battery and both are working fine.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
It's tristar charging chip on board damaged and needing replacement from someone that does microsoldering.
Common symptom is phone charges charged batteries but won't charge flat batteries.
Cost of this repair I'd estimate about $80-$150 from a reputable board level repair shop for iPhones.
Esta resposta foi útil?
Pontuação 2
2 comentários:
I had the feeling this was the case, would this have been caused by the water? Thanks
por
Can be caused by liquid damage but most of the time due to aftermarket cables / cheap wall / car chargers.
por
Adicionar a sua resposta
Isaac Legg será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 59
