Ir para o conteúdo principal
Announced in August 2017, the Galaxy Note8 is the successor to the recalled Galaxy Note7. The Note8 was made available to the public for purchase in September of 2017.
148 Perguntas Visualizar todos
Broken back glass and charging port
Where can i get oem adhesive
, Glass and charging port for unlocked note 8? And did they use uv glue? Acrilic or eco? I would like to maintain as much water resistance as possible assuming i dont mess it up getting to the port. And do i need to replace the camera \ print reader glass \ adhesive? And should i remove all old adhesive? Or leave it in?
Esta é uma boa pergunta?
Pontuação 0
2 comentários
Thank you for the explanation now if i could figure out what type of glue was used and if there are any precut pieces covering all needed areas or i just wing it or use 1 solid piece covering whole back w cut outs for sensors? The barametric preasure test was really helpful and have just the device to test it in.
por
You can get the oem adhesive here.
por
Adicionar um comentário
1 resposta
Pergunta mais útil
UV glue is only used to adhere the glass layer of a screen to the LCD (basically laminated screens).
To maintain water resistance as best as possible, remove all old adhesive that has been separated and replace them accordingly.
To test water resistance without exposing the phone to liquids you use the test menu and check the barometric pressure reading. Applying some pressure, not too much of course you don't want to damage your phone from pressure it should go up and gradually go down upon release of pressure.
Now the expected pressure will vary depending on the phone model, you'll have to search the internet up on that.
Esta resposta foi útil?
Pontuação 3
Adicionar a sua resposta
Patrick F Mclendon será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 151
