Ir para o conteúdo principal
Quinta Geração do Iphone. A Reparação deste dispositivo é correta, requer ferramentas especificas e paciência. GSM/CDMA/16, 32 OR 64 GB/Black or White.
help black screen 4s
i phone 4 screen wont come on but rings power top button dont work for months
what are home and the other button they talk about??
top one power center ? center under screen home button? some say can use volume button??
what can I try/??? thanku
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Home button is the only button at the bottom of the phone with the white square / circle.
Power button is at the top left of the phone the button you use to turn the phone on, lock unlocking phone and turn phone off.
If neither buttons work you need to turn assistive touch on under settings general accessibility.
And you also need to keep screen turned on via auto lock off and if the phone gets locked you would need to plug it into a charger to switch the screen back on.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
dsaunders será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Ao todo: 51
