Ir para o conteúdo principal
Gaming headset with around-ear headphones and removable omni-directional microphone. Shipped with Xbox One audio adapter and a micro USB update cable. Released 2014.
3.5mm jack replacement wiring COLORS?
My headset has no sound coming out of either speaker, im going to attempt to change the 3.5mm jack.
I have a green wire, red wire, twisted green/red with gold copper and just a golden wire.
What do each of these wires do and which wire goes to which part on the new jack??
Any help would be great.
Thanks.
Esta é uma boa pergunta?
Pontuação 2
3 comentários
The copper or gold is usually the ground
por
I have blue red and copper colour thin wires and a thick black.
por
I can ad that this is the same setup for the Turtle Beach Recon 200 Gen 2. There is no other guide or otherwise that I could find that mentions the color coding of The wires in the Recon 200 Gen 2.
por
Adicionar um comentário
12 respostas
Solução escolhida
Wikipedia suggests you're likely going to want to reattach it with the tip hooked to the left channel, the first ring hooked to the right channel, the second ring hooked to ground, and the sleeve hooked to the mic channel, as detailed here.
Esta resposta foi útil?
Pontuação 2
8 comentários:
Yes thanks for that but i dont know whar colors do what??
por
Try taking a look at this, but use the twisted green/red as the ground and the gold as the mic. https://www.youtube.com/watch?v=aLZu7Dbm...
por
Do you put the twisted pair and the mic ground together? Because ive got 5wires and only 4 placed on the jack
por
Usually the mic is grounded on the cable already, so yes, that would be correct.
por
Ive done this and the mic still doesnt work. So what do you think to this?
Red + on RING 1
Green + on TIP
Speaker ground and mic ground on RING2
Mic + on SLEEVE
Because at the moment ive got
Green + on TIP
RED+ on RING1
Speaker Ground on RING2
Mic+ and ground on SLEEVE
and the mic doesnt work.
Thanks.
por
Exibir mais 3 comentários
Pergunta mais útil
Red and Green twisted is the mic wire. You have to seperate the copper around it first because that is the ground wire for the mic. I have done the same with my XO4 Turtle Beach headset.
Red is Right side
Green is left
twisted Green/Red is mic
All copper is ground
Pontuação 5
7 comentários:
so you’ve redone a turtle beach headset?
por
I've followed these instructions and it worked.
por
I have green, red, blue, copper?
por
This is the wiring scheme for the Turtle Beach Recon 70 Gaming Headset. I have rewired/soldered this connection twice. Use a lighter to burn away the little white fibers to separate the wires. These are the correct wire colors (the diagram below is labeled wrong):
Green - Left (Posn 1L)
Red - Right (Posn 2R)
Copper - Ground (Posn 3 GND)
The little white wire inside the red and green wire is the mic ground. Twist this ground together with the Copper - Ground (Posn 3 GND). Use the lighter to burn off the white insulation.
The red and green wire (which has the white wire inside it). Is the mic wire, Posn 4M on the diagram below.
This is tricky to solder. You cannot have any of the connects touching. Use heat shrink to prevent wires from rubbing on the inside of the jack casing.
Anthony's comments above are correct. Thanks Anothony!
por
Hi do you happen to know how the turtle beach headset wires connect to the red, green, white and black wires on a jack? I want to attach wire to wire instead of directly to the jack (I don’t have the equipment to solder)
I tried:
-Twisting the white mic ground to the copper ground and attaching them to the black wire
-red to red wire
-green to green wire
-red and green twisted wire to white
I get sound but the PS4 doesn’t read the mic. What am I doing wrong?
por
Exibir mais 2 comentários
Follow these
Pontuação 1
Here you go!
All the wires (there are 5) are lacquer coated and need tinning prior to soldering.
The note on the diagram is important. You may think you only have 4 wires once you have stripped the insulation.
Pontuação 1
1 comentário:
Thank you, however I believe you have gold & white swapped.. Laur Laur D 57's reply to anthoneys answer was extremely insightful, but I think was calling the GOLD insulated wire "copper" or "all copper". The plug broke on my Recon 70 PS4 headset. I got it third hand, from my homie that plays on PS, but I play on PC. I lack a four pin 3.5mm jack on my PC, so I'm patching the headset with two separate 3.5mm jacks, to accommodate for the separate mic jack on my front panel I/O.
por
I have a Turtle Beach Recon x50, and some of the instructions above were contradictory, misleading or vague, leading to me having to redo soldering, which wasn't fun, and is why I'm posting for clarity.
Disclaimer: Don't burn yourself!
I cut an existing 3.5mm jack from another headset. Just had to connect wires this way.
Preparation:
Step 1: Burn the enamel so you expose about 1cm of copper. Sanding the tips can help but it's delicate.
Step 2: Carefully separate the white fluff, and then cut or burn it off.
Step 3:
Tin the wires. (It's 1000 times easier to solder if you already have some solder adhered to the wire. Use flux to make the solder flow/wick better onto the wire. )
Wire Pinout:
Green Wire: Left channel (Tip)
Red Wire: Right channel (2nd ring)
Red/green twisted pair: Both tied together to GROUND (3rd ring)
White wire: mic channel (4th ring)
Tested and it works.
Hope this helps!
Pontuação 1
3 comentários:
I have a green wire, a all copper wire, an all red wire and a red and gold wire...... they are from a turtle beach earforce p4c. Any ideas which wire goes where on this one?
por
Iv got
Green
Blue
Red and white
Gold
All copper no cover
5 wires 4 places can't figure it out
por
@adie69704 Your colours seems similar to mine, this was what I discovered,
Snipped the wire and saw 2 leads, a white lacquered wire with a copper shield wire twisted around it, and red and green lacquered shield wires wrapped around 2 other wires that were green and blue. So in total 6 different coloured wires. After loads of research and trial and error this was the solution:
Unwrap the copper shield wire and the green and red shield wired and twist these 3 together, these are the ground wires.
The white lacquered wire is the microphone
The green wire was the right headphone
The blue wire was the left headphone
por
Thanks folks trying this tomoz when plug arrives, wish me luck
Pontuação 0
I have red and blue wrapped in copper and a white wrapped in green. Does this mean copper wrapping is ground, white is mic, red is left and blue is right?
Pontuação 0
1 comentário:
Red is probably right and blue is probably left.
por
Does anyone know the wiring onto the pcb in the headphone as my wires have been pulled off the board
Pontuação 0
2 comentários:
[image|2171309]
photo of pcba.
por
Can’t quite make out the wire colours from the photo I can download, can you let me know the couture from left to right? I’ve got white, red, green, green&red, copper colours. It’s a recon 200 head set btw.
por
Don’t have the headphones anymore but still had this
Pontuação 0
I just replaced an aux on a Turtle Beach Recon 500 headset 2021 and this thread was helpful, so I’m posting what I discovered to help others.
Extra help, the wires don’t solder well due to the lacquer, you can use a lighter and sandpaper to expose a good contact OR best solution I found was wack your soldering iron up to 400C+, get a drop of liquid solder on the tip of the iron and push your lacquered wire through the droplet on the iron. This just melts the lacquer and once removed the wire will tin as you go, this may take a couple of drops of solder as the lacquer melting turns the solder dirty and weird. Hope this helps!
Pontuação 0
The color codes mentioned here worked on my Recon 200 Gen 2, thought it'd be worth mentioning because I couldn't find any info on my headsets color coding... And I'm colorblind lol so that didn't help either, had to have my daughter tell me the colors on my wire.
Update (07/19/23)
This is the jack I used, a little hot glue and electrical tape and it works like a boss.
I figure I should also mention, red is R speaker green is L white is V and the last 2 are ground wires.
Pontuação 0
1 comentário:
the red green strip has a white wire inside I believe this is the mic wire. I think the outer wires might have something to do with the switch. I connected all three together and the mic works fine. but the switch does not. But I can use the software for that.
por
I do I'm having trouble with this except for my TalkBack cable only has three wires and they don't have a they look like they're wrapped you know twisted but they're not twisted wires they're twisted around fiberglass there's no wire on the inside of this this is just one wire with fiberglass in the middle of it and there's three of them on my TalkBack cable which is supposed to connect to my controller for the mic not sure if the blue or I guess it looks kind of green the red and green wire are both the positive of the mic, any thoughts would be awesome cuz I'm not sure. Thanks guys 😁
Pontuação 0
Adicionar a sua resposta
Alex ellam será eternamente grato(a).
Visualizações:
Últimas 24 horas: 9
Últimos 7 dias: 38
Últimos 30 dias: 172
Ao todo: 62,561
