Ir para o conteúdo principal
Pequeno dispositivo de streaming de mídia que se conecta diretamente à porta HDMI da sua TV. Lançado originalmente pela Amazon em novembro de 2014. A versão mais recente vem com um controle remoto ativado por voz.
Can't connect to new Wi-Fi...
My firestick is connected to my old Wi-Fi and that Wi-Fi is off now but I'm trying to connect it to my new Wi-Fi and it's not allowing me because it's telling me that it's not connected to my home network. My remote won't allow me to get into my settings to change the Wi-Fi. Can someone help me? Also the charger that came with the firestick is gone so I am using my phone charger. Is that a problem? Help me please someone!
Esta é uma boa pergunta?
Pontuação 25
37 comentários
my firestick is not on my TV
por
My fire tv stick is connected to wifi but after drop the wifi connection anyone help me!
por
I have same issue. Had internet disconnected so got it turn back on but have new connecting information and no way to change it. The fire stick will not let me use the remote so no way to change the connecting info. I have tried unplugging the power from stick, changing batteries in remote, trying a new remote, and there is no way to restore to factory settings without the remote and no way to change network settings without remote. So basically a paper weight now, what a poor design!
por
My Firestick want do anything say it's connected then say it's a problem connecting
por
The fixes in this section are not fixed at all. Bandaid for some. But I have the issue and changing batteries in the remote doesn't work. Unable to select settings or home.
por
Exibir mais 32 comentários
Adicionar um comentário
17 respostas
Solução escolhida
Hi, had the same problem so contacted amazon customer service. Once you get the screen saying “…unable to connect to network…” try to press and hold the home button on your remote for circa 10 seconds - this should bring up in the bottom right corner message that new remote has been connected. Use the remote to navigate to settings to set up your new network. Voila
Esta resposta foi útil?
Pontuação 20
21 comentários:
worked!!
It stopped the search for my old Wifi connection and allowed my firestick remote to access my firestick.
por
Works like a charm with Fire Cube! TY
por
You guys rock! I spent hours trying to figure this out
por
Can’t get remote to go to any channels not the batteries just stuck for some reason on display
por
thank you! I just moved and it wasn't connecting to the new internet. That did the trick. Thank you thank you thank you
por
Exibir mais 16 comentários
In answer to your question about charging, It's fine if you use your phone charger, It's probably not the most efficient since it's not rated for it but it'll be fine.
To get your remote working again and to get to your network settings lets try re-pairing the remote.
• Hold down the Select button for 10 seconds to put the remote into pairing mode.
After completing this step your TV should say in the bottom right that the remote has been paired.
Now you can go to your network settings and set everything as it should be.
Cheers!
EDIT 1/19/2020: Adjusted Wording for Clarity
Pontuação 10
13 comentários:
Woah woah you totally dont understand the actual question. His remote wont work if he has no wifi connected to the firestick! so how can he change any settings!
por
Right! My screen is frozen. I would love to be able to scroll over ...........
por
Try changing he batterys in the remote. This surprisingky worked for me even tho they werent mire than 6 months old.
por
Yes change the batteries.
Unbelievable as batts not that old. Thanks a lot.
por
new batteries and a new remote. I can't scroll because remote will not connect. even tried the phone app. nothing connects
por
Exibir mais 8 comentários
There are lots of users who face Fire stick not connecting to Wi-Fi issue.
Before going to solve the issue we need to know all the possible reasons for occurring this issue:
weak internet signal.
Wrong Wi-Fi password.
Connector problems.
Steps To Fix Fire Stick not connecting to Wi-Fi Issue:
  • Check your internet signal is strong.
  • Verify the signal with other device.
  • Check Wi-Fi Password is correct.
  • Check connector and cables damaged or not inserted loose.
  • Restart your Fire TV device.
  • Unplug the Adapter or power cord for 3 sec.
  • Re-plug it after 5 sec.
  • Restart your Wi-fi.
  • Go to settings>network then press play/pause button.
I hope this will surely solve your fire stick not connecting to Wi-Fi issue, if not then
contact amazon fire stick support by clicking on given link.
Pontuação 9
8 comentários:
I hope your fire stick connected to wifi now. If not comment below i will help you out.
por
I have tried the second one and it's working for me.... Thanks gadget sick.
por
I restarted it and internet is working fine
por
I feel proud to help you jhon.
por
A white screen keeps popping up every time I try to connect my hotspot to my fire stick tv , my hotspot says it’s on but the tv is saying it won’t connect to the internet
por
Exibir mais 3 comentários
I had this problem. I changed the batteries in my firestick remote & that worked, last thing i expected as they were new batterys were only put in 6 months ago!
Pontuação 4
2 comentários:
Settings > my fire tv > reboot
por
Can’t link Fox News to accept my WiFi account
por
It’s as simple as unplugging the micro USB from the stick itself and plugging it back in. This should work.
-Mike
Pontuação 3
2 comentários:
This worked! Thanx Mike!!
por
Thank you this worked for me.. it took about :30 secs.
por
Sometime user might come across Wi-Fi connectivity issue while using the Fire TV device. More reason behind this error such as wireless router, router configuration, wrong account setting, wrong Amazon account, outdated software version and more.
If you are recently moved to another country then change the country and language in account setting. Otherwise, you can get error “Fire stick won’t connect to Wi-Fi” as well as” Registration Failure Error”.
You can try restarting your device or Wi-Fi modem. If restart doesn’t work to troubleshooting fire TV won’t connect to Wi-Fi then you have the option to reset your modem.
Pontuação 2
Pontuação 1
Download the Firestick app and if it connects to your TV it will enable you to make the necessary changes.
Pontuação 1
1 comentário:
That wont work as the firestick is not connected to a network so the firestick app will not be able to find the firestick.
por
Factory Reset fixed problem. Kinda annoyed though. Hassle and unnecessary error in coding or something.
Pontuação 1
Anyone with a firetv first generation (I don't know if 2nd gen has a usb connection in the back) u can use your PS3 or 4 control? I dont know which one my son has. I plugged it in with a regular usb charger (The one I used to charge my android phone) and immediately was able to access my box and pair my remote and connect to my network. I was so desperate to fix it and tried that and it worked like a charm!!! Soooo easy Too.
Pontuação 1
For the connected with problems from galant2004**try a hard restart by pulling the power cable (USB-Mini plug) out of the Fire Stick for about 5 seconds. Having then reconnected it, the Fire Stick rebooted. Almost like magic the unit went straight to the Home Screen. I was back up and running**. Mine wouldn't detect a previously forgotten network that I needed to use again. I had to press home button for 5-10 sec n go do the reset option that way and 4 some reason also change the HDMI input on tv to HDMI 2 instead of one because it acted like it was broke with a black screen. But only do this if the starred section(**) is not working. I did not have to factory reset it finally detected it. To control one without Wi-Fi or remote use a Bluetooth remote with phone until we get u one.
Pontuação 1
1 comentário:
I've had a firestick for the past 3 years and worked fine but as soon as comcast up dated their systems. My stick will not connect to wifi but the wifi connect to everthing else in the the house and all comcast can tell my me is to call amazon and they know that they did something to your tv so it won't connect so you canbuy their sorry ass cable.
por
I fixed it! There is a “reset firestick to factory settings” command in the settings menu. You have to dig a little for it. After it resets, when setting up as new, firestick connected to my new wifi without any problem. Then it proceeded to update and go through various reset cycles, which took some time until finally promising to give up all my privacy rights lol, it works fine again.
Pontuação 1
Fortunately, just a restart can solve this issue. if this dosen’t works then you can re-establish wifi network on firestick. it will definitely work.
Pontuação 1
1 comentário:
but it will erase all my stuff on my firestick? Can i do this without it erasing everything on my firestick?
por
I bought a used firestick from a friend ….I'm using the firesrick remote app on my Android for my firestick because she had lost the original remote …but I got a new WiFi network and I can't get into my firestick because it isn't the same WiFi network as the previous one it was on…how can I get my remote on my phone to pair to my firestick so I can get in and factory reset my wifi and reregister the whole system into my name and email and account
Pontuação 1
1 comentário:
Hey , i want to know why my fire stick show's 3 connections on my amazon account ,when i have just opened 2 . please let me know
por
Down load the Fire stick app to your phone. The app remote works.
Pontuação 0
4 comentários:
Again the firestick app needs to find the firestick but without network connection to the firestick it cant find it.
por
I still haven't seen an answer to your question as this is my problem. The Fire TV phone app isn't recognizing the firestick as there is no network connection...I'm on vacation and forgot the remote...how can I change wifi setting to the wifi here at the vacation house?
por
Make a hotspot with the old network name use a 2nd device to connect to the hotspot. Then on that device you download the fire stick app. From that device you'll be on the network of old through hotspot tricking the stick so you can change the network settings.
The best I can think of besides reboot Nd loose all your old saved apps VPN data etc. It's frustrating and takes a minute but it works. Let us know how it works out...there's a video on this on youtube.as we know the remotes a crap and stop working,batteries die in 3 days haha.but it works.
I moved no old network to use to connect to. Best bet is ask Amazon to make a option on these that is universal to/ or when moving or service disconnected or new company wifi provider. It a headache.
por
Hello I am an MSCE, and Network administrator. I have come acrossed this scenerio before. Some hardwares do not play well together. Comcast Cable means a new box! If you did not forget the original network in the firestick and then reconnect it is not going to connect.... Do this. "Its a conflict with encryption algorithms on the new Modem causing your problem" Just remove the wifi password on modem, Make it unsecured. Then it will connect no problem. This is a known issue in the field with certain ISP owned modems. If its an existing modem, then it may just be a firmware update on the stick or modem that caused the disconnect... Either way this will work.
por
My fire stick would pick up wifi signals from miles away but it won't pick up or connect to router that is literally next to it. I've tried everything. Please help
Pontuação 0
My fire stick is not working it say connect to wifi settings then won't let me get into settings it's goes to screen with water and trees
Pontuação 0
Adicionar a sua resposta
Kia será eternamente grato(a).
Visualizações:
Últimas 24 horas: 11
Últimos 7 dias: 107
Últimos 30 dias: 455
Ao todo: 424,437
