Ir para o conteúdo principal
Introduced in September 2004 and replaced with a version in 2010. The following model numbers apply: ZA11S, ZC71S, ZC11S, ZD11S, ZC21S, ZD21S, ZC31S.
19 Perguntas Visualizar todos
Why is my ABS and hand brake light on all the time? RESOLVED
Hi guys I would appreciate your help. I have a suzuki swift ZC31.the ABS and hand brake light is on all the time . How do I fix that?
Update (03/12/2018)
Apparently the ABS module had failed.And was swapped out with a junkyard replacement.
Esta é uma boa pergunta?
Pontuação 3
1 comentário
My breaks ar light weight
por
Adicionar um comentário
1 resposta
Pergunta mais útil
I had the same problem. I purchased a used ABS pump from a scrapyard and it solved the problem.
Use your smartphone to photograph the labels and numbers from the failed pump, to ensure that you get the right part.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Joseph Fernandez será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 708
