Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Perguntas Visualizar todos
Phone battery drains after spark in replacement.
Hey guys,
So a few weeks ago, I sent my phone off to a 3rd party repair shop due to error 4013. They fixed it and sent it back. However, their battery was not holding charge. I replaced the battery myself, and it went a huge success. Except one thing..
For some reason, the phone charges fine, but when in use gets hot near the bottom, and will be flat in about 1hr. During the repair, I used a metal spudger instead, and caused a spark when disconnecting the battery to the logic board.
I have tried a reset through DFU mode with no change.
Any ideas? Do you think that it could be a U2 chip failure?
Thanks
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Probably one or a combination of a few things:
- Shorted small SMD components near battery connector
- Bad tristar chip.
Anyway both will need micro-soldering to fix.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Alexander Thomas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 154
