Ir para o conteúdo principal
Dell Inspiron 15-3531 laptop with an Intel processor and a non-touch display.
14 Perguntas Visualizar todos
My laptop is overheating!
My laptop is overheating. I have been told that I may need a new fan but I don't want to assume that's the only solution. What is something I can do at home before getting the fan replaced by a specialist?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Karen! The first thing you should do is make sure your laptop is not sitting on a bed or similar surface as this can block the airflow of the fan and cause your laptop to overheat. If your laptop still feels hot on a cool, hard surface like a desk or table, the fan might be either dusty or broken. You can try to clean the fan; however, if you are still dealing with issues, you may need a replacement fan.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Karen Wright será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 11
Duração total: 278
