Ir para o conteúdo principal
The Stylo 2 (model number LS775), the second iteration of the Stylo series, is manufactured by LG and was originally released in April 2016.
81 Perguntas Visualizar todos
Sound is not working
I only have sound when using headphones. How do I get my speaker to work?
Esta é uma boa pergunta?
Pontuação 3
3 comentários
I have to same problem it say my headphones are in but they are not
por
It shows headset logo on screen and sound is not working
por
I am having the same problem with my LG Q Stylo+. If anyine has anyrhing to help please contact me at aedanouellette@gmail.com
por
Adicionar um comentário
5 respostas
Pergunta mais útil
Tried various fixes I found online for the same problem with my LG Stylo2. This is what worked for me....Remove the back cover of your phone and push on the speaker (left bottom) a few times. All of a sudden I have sound again. Loose wire likely cause inside speaker!! Hope this works for you.
Esta resposta foi útil?
Pontuação 7
9 comentários:
Thank you!!... I tried all sorts of things to get my speaker working again!... I almost did a factory reset on it.. Who would've thought something so simple would work! Lol.... Thank you again for your advice!
por
Thank you! This worked.
por
I am so glad. Did not know if this would last but 4 months later and mine is still working with no problems. Glad I could help.
por
It worked for me too!!!
por
and anotha one!!!!
por
Exibir mais 4 comentários
You got to take the back off and screws out take off souronding plastic molding there is 2 pins connected on the speakers itself they must be touching the tape or ribbon perfectly or you will not get sound go to YouTube for video on how to take phone apart properly
Pontuação 1
Had the same issue took it all apart & put it back nothing, sprayed the contact cleaner ,pulled the speaker out tested it outside it was good, then i saw where the speaker sits if you push the cover you'll hear a click that is the notch that pushes the cover & makes the contact.
Pontuação 1
2 comentários:
thanks so much i try this way my problem was resorve .
por
The push and click worrrrrked! Thank you so much!
por
Pontuação 0
Pushing of speaker repeatedly from left to right or from right to left by removing just back cover
Pontuação 0
Adicionar a sua resposta
Geneva Campbell será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 12,647
