Ir para o conteúdo principal
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Perguntas Visualizar todos
Can I replace an SE with a 5s screen?
I have once already replaced my SE with a 5s screen as I could not find any difference in the screen last time I replaced my phone screen.
I had to replace my screen again, when I as at the store AT&T to get a replacement screen immediately. The guy said there are glitches in the screen if you replace an iPhone se with a 5s screen. To my knowledge at the time, I didn't think this was right. I bought the screen anyway as I needed it. Now the screen is glitching. The best way to describe it is, the screen is gone fizzy every part of it works, touch and all.
Since the guy said there was no returns I wanted to see if he just gave me a bad screen or did what he warn me about is true. I couldn't find anywhere that the LED screen in different or problems occur with a 5s sceen on a SE. I know batteries are different and the fingerprint scan.
Any advice to tell me i'm an idiot for getting a 5s or should they work and he was just trying to offload a dodgy screen...
Thanks.
Esta é uma boa pergunta?
Pontuação 1
2 comentários
@reedcrosby04 what are you merging this with? can't see the one your merging it to.
por
I successfully replaced an iPhone 5SE screen with one from an iPhone SE. The touch ID did not work though, so I had to replace this button as well (black on an original white... oh well!), Success. Three phones, 4 years later and it appears I have a good 5SE, first edition now. Thanks for the encouragement.
por
Adicionar um comentário
2 respostas
Solução escolhida
I've worked on multiple 5s & SE models, and i havent found any difference between them as the screens are completely interchangeable. I have heard however that aftermarket/cheaper screens give problems when not put on their respective phones. As long as you get OEM screens or at least ones from a reputable source, everything should be fine.
Sounds like the guy at the store either gave you an aftermarket screen or a bad one in general. Try putting it on another 5s & see if the problems persist
Esta resposta foi útil?
Pontuação 4
2 comentários:
I think it was an after market product.
por
por
You can't use an aftermarket 5S screen on an SE without display issues.
But you can use an original 5S, SE or aftermarket SE screen on an SE.
Pontuação 3
2 comentários:
That must be the case.
por
Hi Ben,
I had no issues except for the Finger Print button. All is working well.
I had to make some choices:
1/ A partial issue on the top of a 5 SE screen and no Finger Print recognition
or
2/ A good working screen with an incompatible Finger Print reader
I took option 2/ ... then I replaced the fingerprint reader from a third SE screen.
All these are authentic Apple Parts from iPhones.
Now all is working well.
That has been my experience.
por
Adicionar a sua resposta
Michael McNabola será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 30
Últimos 30 dias: 139
Duração total: 10,273
