Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Not Charging after replacing battery
I was trying to replace the swollen battery in my daughter's iPhone 5s with a recently purchased and functioning iPhone 5c battery. I have replaced batteries and screens on the iPhone 5c devices several times, so I am familiar with the care needed to not damage ribbon cables and connectors during the swap. After replacing the battery though, her iPhone will not charge. I removed the battery and put it back into the iPhone 5c and it charged just fine. Also, when the battery is charged, I was able to sync the iPhone 5s to iTunes and saved a back up of her files, photos and music. I checked all of the connections several times, including the small single wire that plugs in near the battery plug and the plug from the charging port. I do not have a USB Ampmeter to properly test it as I am a DIY type. Any thoughts on what to look for?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
Pergunta mais útil
Either the charging port is busted or the Tristar chip needs replacement which requires micro-soldering work done on the phone. You can find reputable repair shops that offer a no-fix no-fee model to get them to fix it for you.
You can quickly test tristar by unplugging the battery then plugging the charger in and see if it shows apple logo or not, if it does not then the tristar chip is not. Usually I would test another charger port if possible to rule that out.
Esta resposta foi útil?
Pontuação 1
2 comentários:
So, without the battery installed, if I plug the iPhone into the lightning cable and charger to power, I should still get the Apple logo? I tried it, I put the screen back on but did not reconnect the home button and plugged it into charge, I did not get the Apple logo, that means the chip is busted. Is that correct?
por
Yes if you can't get Apple logo to appear when screen is connected and battery unplugged Tristar chip needs replacement.
por
The 5C battery is not the exact same as the 5S battery even though it does fit. Try ordering a 5S battery and see if that fixes the issue.
Pontuação 0
1 comentário:
They both work vice versa On 5s and 5c, that's not the issue.
por
Adicionar a sua resposta
Donny Sanders será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 3
Duração total: 1,795
