Ir para o conteúdo principal
Released May 2012, identified by model number J2011-03-US.
20 Perguntas Visualizar todos
Jambox power button repair (original)
I have an original / classic jambox, but it sometimes turns on by itself. I can't really find any guides on the original jambox. Does anyone have any? Is it possible to replace the power button assembly/board? (guessing that is the problem?)
Thanks in advance
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Solução escolhida
Sadly, Jawbone went out of business so getting new parts is not possible. You'll need to find a second unit to steal the part from.
The slide switch overtime breaks down and needs to be replaced.
Esta resposta foi útil?
Pontuação 0
Anyone know where to find a dead Jambox to scavenge for parts? I’ve been needing to replace my power switch for years. Yes, I can solder the tiny connections.
Pontuação 0
Adicionar a sua resposta
Thomas Debie será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 729
