Ir para o conteúdo principal
Wi-Fi only variant of the fifth generation of iPad, released in March 2017. Available with 32 and 128 GB storage options featuring a 9.7" Retina display and 64-bit A9 processor.
home button assembly and cabe
I ordered a home button assembly for the ipad 5 from ifixit. It did not include the home button gasket. Am I supposed to use the old home button gasket. Thanks
Allen
Esta é uma boa pergunta?
Pontuação 0
1 comentário
thank you so much
por
Adicionar um comentário
2 respostas
Solução escolhida
Thanks so much for your help
Esta resposta foi útil?
Pontuação 0
Pergunta mais útil
Take a look at Step 48
“Press the home button from the external side of the digitizer to break up the adhesive holding it in place.
Apply pressure slowly. The adhesive is attached to a delicate gasket that will tear easily.”
If the gasket is secured to the old home button carefully remove it to be applied to the new home button.
Make sure the adhesive is warm with the iOpener or you may tear the gasket.
Pontuação 1
Adicionar a sua resposta
Joe Gibson será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 14
Ao todo: 137
