Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
iPhone stick in recovery mode after new battery fully drains
After putting in a new battery in my 5s, I used it until it hit 1%. When it did, I got stuck in a boot loop, with some cases when it would boot into IOS but then go back into the loop. I put the phone in recovery mode so it wouldn't continually loop and then I let it charge (because it's a new battery) After some time, the iTunes logo was gone and the phone is in recovery mode and won't get out. I tried update, restore, and even DFU restore, but they all get stuck on the part when iTunes and other tools say "waiting for iPhone." At that point, it just boots back into the "black screen recovery mode."
Any ideas?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Why did you replace the battery in the first place?
Have you tried the reset using a different cable/charging port? (maybe port was damaged during battery replacement?)
Is there any pry damage around the battery connector? (component knocked off somewhere?)
Have you tried a different battery?
And lastly, do you get an itunes error? If so which error is it?
Esta resposta foi útil?
Pontuação 0
5 comentários:
I replaced the battery because the old battery was gone and drained in a matter on minutes. I have tried many different ports and 3 different cables. Nothing is broken, inside or out, and iTunes does not throw an error. It's just as "waiting for iphone" forever. I still need to try another battery too.
por
If the battery doesn't provide proper voltage on low battery it can cause this issue.
Kind of a hassle to diagnose but another battery would need to be tested on there to confirm this.
por
Ok I tried another battery. Exact same problem
[UPDATE]
I noticed that the phone won't power on to the dead battery screen at all on either battery too.
por
Okay, so this issue can be caused by a faulty Tristar (charging chip) on the logic board.
A reputable repair shop that does micro soldering with a no-fix no-fee model can diagnose this issue for you.
por
Ok, I'll try that
Thanks!
[UPDATE] ITunes now goes up to "preparing iphone for restore"
por
Adicionar a sua resposta
Arush A será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 1,108
