Ir para o conteúdo principal
could not activate iPhone
hi guys i need help :( ...my iphone 6s plus is stuck on "could not activate iphone, activation server coud not be reached" i dont know what happen.. this is the third time i reset it..last time i reset my phone was ios 10.3.3 but nothing wrong happen,,but now i tried all recommendations on internet and tried like changing sim cards or restoring it but nothing happen it always go back on activation server could not be reached...is it already a hardware issue ?(but i doubt it)
can someone help me please?if someone has the same problem before please tell me what to do... thanks....
(will just switch to android if this one wont fix)
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Solução escolhida
Probably baseband chip needs to be reballed and jumper wires used for weak pads.
You can confirm if it's baseband chip issue if you get no imei on the blue information icon at bottom right when it says slide to unlock on lock screen.
Esta resposta foi útil?
Pontuação 1
1 comentário:
thank you for your reply
'..and yes i did check it and it still have the imei and the serial number..i tried a lot of things already..if only i can try to restore it but itunes is not giving a way to restore to a lower ios like 10.3.3 ...
por
Adicionar a sua resposta
g b será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 7
Ao todo: 2,264
