Ir para o conteúdo principal
iPad Air Wi-Fi + Cellular, modelo nº A1475. Disponível em cinza-espacial ou prateado, com configurações de 16/32/64/128 GB.
Can I use an A1474 main board as a replacement?
A1475 logic boards are quite expensive, while A1474 boards seem much more readily available. From my uneducated perspective, the major difference between the two is that the A1475 has a spot to hook up the LTE antennas, and I'm sure some circuitry to process it.
Can I slap an A1474 board in there and just not hook up the LTE antennas, and use the unit as a Wifi only Ipad? The reason the board is bad in the first place is the power management chip is bad (confirmed by replacing the battery and still not being able to charge).
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Yes, you can always just not connect the LTE antennas. But then, you'd just have no LTE at all, and your frame would say you had a A1475 iPad, so then you blow all chances of ever doing a Trade-In, and selling it would be a hassle to explain. But if that does not bother you, yes you can just not connect the LTE systems and use it as a WiFi iPad Air.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Mark Herter será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 10
Últimos 30 dias: 34
Ao todo: 720
