Ir para o conteúdo principal
Lançado em 4 de novembro de 2017. Modelo A1865, A1901. Disponível com GSM ou CDMA / 64 ou 256 GB / Prateado ou Cinza Espacial. (Pronunci-ase com X como número romano, isto é, iPhone X é o mesmo que “iPhone 10”.)
1199 Perguntas Visualizar todos
bluetack stuck in speakers :(
Hi guys
stupidly i pressed on the bluetack a bit too hard :( and this got stuck in my iphone x speaker grill.
what is the most safest way to clean this? :/ its driving me nuts!!!!!!!!! this phone is brand new and hardly used.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
2 respostas
You're going to want to use a soft bristle toothbrush and try and get it out. Another option is a toothpick but be gentle so as to not damage anything. And who knows how long it will take, but be patient take your time and just work on cleaning it out. Why were you pressing glue on it in the first place?
Esta resposta foi útil?
Pontuação 0
3 comentários:
Hi mate
Thanks for the quick reply .
To be honest, I just wanted to remove the debris stuck onto the speaker mesh. And stupidly I pressed a wee bit too hard onto the speakers with the bluetack.
Mate, should I let that bluetack stuck in; to dry out and then use the bristle ? Or should I try to scrape it off right now ? Since it’s still goey around in the edges of the speaker mesh.
Your input is highly appreciated . Cheers
por
Sorry for the late reply. But in all honesty I’ve never encountered such a sticky situation (pun intended) but yeah remove as much of the goey portion as you can, and whatever is left when it is dry attempt to brush out. When removing the goo ensure you don’t push it into the mesh further.
por
Did anything work mate got the same problem with my airpod I put blue tack to clean and I’ve got it stuck
por
Maybe try a little hot glue. You'll never get it out with no bristle brush.
Pontuação 0
Adicionar a sua resposta
Zohaib Shaikh será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 10
Últimos 30 dias: 50
Duração total: 5,778
