Ir para o conteúdo principal
6S No charging symbol, still charging up but not past 11%
Hi there, this is my first time posting on iFixit as I've run into an issue I haven't seen before.
I have a customers iPhone 6S which isn't charging, I've tested charge port and battery to no avail, and also tried device in a known good housing assembly.
The device charges with no charging symbol or sound, however it only charges up to 11% (roughly) and stops. I left it on charge overnight and arrived one morning to find it on 6ish%, hence my confusion.
Would this be tristar? How would I know, and what can I test to find out?
Device has not been water damaged, and came in for a screen replacement initally.
Have done a mainboard inspection and can't see any obvious burns or damage.
Kind regards,
Silas.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
Pergunta mais útil
If you can't get Apple logo with battery unplugged and charger plugged in then Tristar is bad.
Esta resposta foi útil?
Pontuação 2
2 comentários:
That's an incredibly helpful peice of information. Thank you.
por
So what what it? This is my problem on my phone right now.
por
Adicionar a sua resposta
Silas será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 5
Duração total: 1,994
