Ir para o conteúdo principal
Um videogame de tv fabricado pela Sony Computer Entertainment, também conhecido como PS4. Primeiramente anunciado em 20 de fevereiro de 2013 e lançado em 15 de novembro de 2013.
1697 Perguntas Visualizar todos
My ps4 switches on but with no signal
My ps4 switches on completely but with no video at all. I have switched TVs, changed hdmi ports, changed hdmi cables and even a month or two ago got a completely new hdmi port on my ps4 put in and it worked fine until yesterday. Ive even tried going into safe mode but no luck. My ps4 was on and th light was blue etc. So I decided to put my headphones in and I can hear in my headset the menu and all the noises when navigating. I really need some help as soon as possible.
Esta é uma boa pergunta?
Pontuação 3
Adicionar um comentário
2 respostas
Pergunta mais útil
if you replaced your HDMI port yourself, which got it working, then it stopped working again, it could very well be that the HDMI port either went bad, got damages, or pulled a pin off the board.
if you have good experience with soldering, Attach anotherone yourself. if you dont solder often, i suggest getting it repaired through a store.
if the HDMI port doesnt fix the issue, run through a reflow on the GPU. This may getit working.
if it continues to fail, then you are looking at a board failure. in this case, replacing the device is your best option.
Esta resposta foi útil?
Pontuação 3
The first thing you need to do i go to best buy and buy a new ps4 hoped i helped
Pontuação 0
1 comentário:
== Heading text== == Heading text ==== == Heading text ==== == Heading text ==== == Heading text ==== == Heading text =='bold text' == == == == == ==
por
Adicionar a sua resposta
Ihsaan Khan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 9,619
