Ir para o conteúdo principal
O iPhone 5s da Apple foi anunciado em 10 de setembro de 2013. O reparo deste dispositivo é semelhante ao de modelos anteriores e requer chaves e ferramentas de abertura. Disponível como GSM ou CDMA / 16, 32 ou 64 GB / nas cores prata, dourado e cinza espacial.
3530 Perguntas Visualizar todos
Unresposive touch screen - screen problem ruled out
Hi there,
I have come across a strange thing with the phone of my boss.
He told me from one moment to another the touchscreen became unresponsive.
I took the phone, dissassembled it, tried with another screen only with cables connected, no shielding bracket, worked. Then a cleant the socket and the plug with isopropanol of the original screen and tested it, still without the shield, it surprisingly worked. I reassembled the phone with the shield, switched it on, no touch again. I tried with the other screen assembled, doesn’t work. My ideia is the touch ic, isopropanol might help but after evaporating, the problem comes back. I don’t think it can be anything with the screen.
Any thoughts from you?
Thanks.
Tamas
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
check the connection on the board, ensure none of the connections are bent. Works with EMI shield off then when placed no touch-try backing off the screws by a 1/4 turn.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Tamas Korodi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 40
