Ir para o conteúdo principal
In 2002, the third-generation model was introduced which saw the model move further up-market. Planned and developed under BMW ownership the third generation was to share components and systems with the BMW 7 Series.
5 Perguntas Visualizar todos
Where is transfer box relay location?
No relay - control module behind battery
Esta é uma boa pergunta?
Pontuação 0
3 comentários
Michael West what year and what model is this? What are you referring too with the "Transfer Box relay"? What does or does it not do?
por
Michael West okay so you found what you were looking for?
por
If it is a 4wd or AWD and you are talking about the transfer case, it is under the vehicle. They used to be between the gearbox and the rear diff. Now I suspect it is all electronic.
por
Adicionar um comentário
1 resposta
Solução escolhida
If you are referencing a relatively new Range Rover up to 2012 model year, it does not have a Transfer Case relay in a physical sense. All T-case related functions are controlled by a Transfer Case Control Module. All functions once ran by a relay in older models (Say switching from low to high range) is now transistor controlled by the computer. I would suggest having the vehicle diagnosed by a technician using Symptom Driven Diagnostics (SDD) software to isolate whether the problem is Sensor, Switch wiring or actuator related.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Michael West será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 26
Duração total: 1,318
