such bad luck, I bought one for my son, worked when I plugged it in, played for three hours, turned it off to go to bed, next day turned it on and nothing! intermittent music but thats it. no way of starting in safe mode, didn’t move or touch anything since day before, guy I bought it from tries to tell me its the cable even though it worked the day before . gutted as he won’t give me my money back. if it worked yesterday why not today? frustrating. don’t fancy a costly repair, tried all what I read except new cable, but as I said it worked yesterday fine. just a black screen flickering . how about if I drop it from the third floor! got scammed last month buying one from gumtree and didn’t receive it, my boy has tears and I can’t go out and buy another, thats £350 spent so far on two machines in a month and still can’t play. it would have to be new now but £600+!! thats a lot to folk out in all its entirety , sick as a pig
When you say safe mode isn't coming up, have you attached your controller to the PS4 via a usb cable? As that is the only way to get safe mode to start.
por sm_vulkus
I had the exact same problem. I unplugged the ps4 for 24 hours and connected the hdmi into another port before turning it on. It worked! I then powered it off and then connected the cable back into the original port and it still worked. Not sure if it had something to do with the amount of time I had it unplugged or if it was switching ports.
por Curtis Griffin
My question is, my ps4 does this but only for one tv that I own, I’ve hooked up other things to the tv via the same HDMI cable and port and they work perfectly, I’ve also hooked up my ps4 to another tv in my room with no problems via HDMI so I know it’s not my ps4 either
por Chandler Rayborn
Mine suddenly started doing this also !!
por danieltapp
I have the same problem, but you have solved the problem.
por Damjan Forjanic
Mostrar mais 34 comentários
