Ir para o conteúdo principal
Need disassembly instructions to replace Keurig K70 air pump
Partial cups of coffee. Done the easy and usual: clearing the puncture pins of debris, filter at bottom of reservoir, descaling with vinegar. Now I am convinced it has to be a weak air pump.
I'm looking for a way to remove the guts to get access to the air pump. I'd like the results to be cosmetically pleasing, so the hacksaw solution is not acceptable.
Esta é uma boa pergunta?
Pontuação 2
3 comentários
I have the same problem? Any answers yet?
por Compartilhar
Sorry to say, I put that Keurig in a bag on the shelf in the garage awaiting some further inspiration. I have not had progress, other things became more important. Probably end up buying a new one…. I have been using a smaller Keurig labeled with Mr Coffee logo and that one, too has started has started to make 1/2 cups… Common fixes don’t work for that one any longer Gee Whiz….
por Compartilhar
Nobody knows how to take a keurig apart? I might as well tinker blindly! Will post if I have any luck.
por Compartilhar
Adicionar um comentário
1 resposta
Pergunta mais útil
Here’s a video on how to fix it:
xhttps://www.youtube.com/watch?v=CuczMT3R...
Esta resposta foi útil?
Pontuação 2
1 comentário:
Been there and agree that’s the problem, but there is no instruction about how to remove the guts to expose the air pump for replacement!
por Compartilhar
Adicionar a sua resposta
Eric Andersen será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 1,938
