Ir para o conteúdo principal
Babá eletrônica com monitoramento de movimento e som Angelcare AC401, produzida desde 1999.
Lcd screen doesn't display
Good day, I hope you might be able to assist me. I bought a second hand angel care movement and sound monitor but after I received the monitor I found that the parent unit doesn't display anything. I replaced the parent units batteries and charged it for hours. Yet no display, I did speak to angel care South Africa but they informed me that this model has been discontinued.. Is this device fixable? Or will I have to purchase a newer model?
Kind regards,
Adri Van Heusden
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi @adrivh ,
Did you hold the monitor unit On/Off button for 2 seconds to turn it on?
If you haven't got one, here is a link to the User Guide for the Angel care AC401 baby monitor
Did the seller of the unit say that it was in a working condition?
If so, I suggest that you contact them about the problem or get a refund.
If it was sold, as is, with no further information provided then here is a link to the ifixit Desmontagem do babá eletrônica Angelcare AC401 guide.
It shows how to open the unit so that you can check for any obvious problems such as broken wires, dry joint connections, burnt out components etc. Use a DMM (digital multimeter) to check that the full battery supply is reaching the circuit board.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Adri Van Heusden será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 29
Ao todo: 9,111
