Ir para o conteúdo principal
External storage options by Seagate, usually connected by USB, available in many storage sizes and form factors.
How to remove hdd from a Seagate 4TB expansion drive and access files
I have a 4TB Seagate expansion drive (long out of warranty) which was knocked off a table and will no longer power up. Can someone walk me through the process of removing the hdd from the expansion case and setting up an hdd reader to let me access the files?
Esta é uma boa pergunta?
Pontuação 0
1 comentário
@mapiper any model on this drive?
por
Adicionar um comentário
3 respostas
Pergunta mais útil
Cracking open the case won't help you to gain access to the files as it sounds like the platters and/or heads are in trouble here. I'm assuming the case its self is not damaged (the port and power connectors are intact).
At this point I think you're going to need to ship the drive out to a recovery service if the data is still important. It won't be cheap ;-{ Data Recovery Services
Backing up is so important! I even back up the back up ;-}
Esta resposta foi útil?
Pontuação 1
See if this guide will help you figure out how to get the enclosure open:
Seagate 5TB External USB3 Teardown
Pontuação 1
The case is okay the power connector is broken at top
Pontuação 0
1 comentário:
@vickitayor - How about creating your own question posting a few pics so we can see the damage.
por
Adicionar a sua resposta
Michael Piper será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 45
Ao todo: 2,991
