My Toshiba TV can not power on
Hi Pro,
My 50" Toshiba TV can not power on...
No standby light, no respond and no picture at all when switch on
Have tried to unplug and leave it for 1 minute and plug in. Power source is good, fuses are continuity, voltage are as per stated like 24v, 5v, 2.4v, 3.2v, all physical look of capacitors are good and tested by multimeter...
Please help. Thanks a lot in advance.
Power_tv. 2.4v
Ac_detect 3.2v
Other voltage as label or 0v
Esta é uma boa pergunta?
Pontuação
0
@jackiechan83 where did you test? At what point do you measure these voltages?. If you have a totally dead set the issue would be indicative of a bad power board. How did you check all the caps with a multimeter? Post some images of yor boards etc. with your question so we can see what you see. Use this guide for that Adicionar imagens a uma pergunta já existente
por oldturkey03
Hi, thank you for reply. Added images and more details
por Jackie Chan
