Ir para o conteúdo principal
"The worlds smallest 15.6-inch laptop packs powerhouse performance and a stunning InfinityEdge display all in Dell's most powerful XPS laptop."
20 Perguntas Visualizar todos
Why my fans are running all the time?
My Dell XPS 15 has this problem: fans are always running, making lots of noise, even when computer is idle, or having just 3-4% jf CPU load. (earlier when I just bought it it was very quite, fans started up only under high usage).
Can it be that after a year of usage my cooling system is full of dust? Should I clean it?
Unfortunately there is no instruction on iFixit.
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
1 resposta
buy a can of compressed air and clean the fans air ducts. Be sure NOT to make the fan spin as you can damage the motor. have a vacuum nearby to clean up the dust.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Roman será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 2,154
