Our power went out at home and wave radio will not power up at all?
Wave radio will not power up. Is this an issue that can be resolved?
Esta é uma boa pergunta?
Sounds like a power surge my have blown the fuse in it.
open up unit
Look for fuse (should be aroung where the power comes in)
Remove fuse and get a replacement
Reinstall and re assemble unit
Esta resposta foi útil?
And, make sure plug has been REMOVED from the wall before doing this. :)
Hi Bo, Before checking the fuse, what type outlet is it plugged into. If it’s a GFI type outlet, see if it may have tripped. You can reset it on the outlet. If it’s a regular outlet, plug something else into it like a small lamp. If no power then check the breaker to see if it tripped, if not then check the fuse as Overdrv said above. I hope you get it back up and running. Please let us know.... Thanks, John
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 16
Duração total: 1,303
