Ir para o conteúdo principal
This instant camera from Fujifilm now boasts a slimmer and lighter body than previous revisions. The Mini 8 helps the photographer by alerting them the recommended aperture. It also has a High-Key flash mode which helps the photographer attain soft portraits for a stunning look.
Pictures turn all white
I have a problem with my Instax mini 8. I took a few photos today, the brightness was well adjusted (it marked the bright sun) but all the pictures turned out completely white, except for some little colour parts, but nothing was visible on the picture. Is the camera the problem? Or is it the film?
Esta é uma boa pergunta?
Pontuação 2
Adicionar um comentário
2 respostas
Quite often this happens on digital cameras. Because the battery needs replacing or you have not shut the battery compartment correctly. There already is a question posted. Go through this thread:
Why does the fujiflim come out white
Esta resposta foi útil?
Pontuação 0
2 comentários:
Yes, but mine is not a digital camera...
por
Just because it does not have a LCD screen on the back does not mean it is a mechanical/manual camera.
por
Hi Rose! If you were taking a photo in the cold the ink can actually get too cold and the image will never develop. But if you were not taking images in the cold, i’m not sure.
Pontuação 0
Adicionar a sua resposta
Rose será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 16
Ao todo: 14,584
